1. jenluvs2sing's Avatar
    I was using chomp today, no problems, then for no reason I can tell all of my texts are gone. Anyone else having this problem?
    10-15-2011 09:54 PM
  2. chud's Avatar
    There is a setting in the stock messaging app to delete texts once you hit a certain amount. Look for that.
    10-15-2011 10:06 PM
  3. jenluvs2sing's Avatar
    thanks, because it deleted everything! I'll give that a try...
    10-17-2011 08:31 AM
