[INFO]Just throwing this out since it seems people are having problems finding the downloads... This was the same package & instructions that were first leaked on the ICS 4.0.4 package that I downloaded and saved for my own personal use.
This does not require root or root your device. This is just pushing the ICS 4.0.4 leak to your device and nothing more. You can root this if you choose by seeing our Rooting guides in the Rooting & Hacking section.[/INFO]
[WARN]Neither Android Central or myself take any responsibility or credit for using this... Flash at your own risk.[/WARN]
Odin 1.81
ICS 4.0.4 package
Instructions...
1. Download the above 2 files.
2. Using 7zip extract the contents of the IMM26.zip to a place on your computer
3. Run the Odin3+v1.81.exe file on your computer
4. Power off your device (phone)
5. Press and Hold Volume Up+Down together and while continuing to hold momentarily TAP the POWER button. You should then be in Download Mode.
6. Plug in your device to your computer using your USB cable.
7. If a connection is made between your device & computer you will see a YELLOW light up box under ID:COM in the upper left hand corner of ODIN with some numbers inside the box (ignore the numbers).
USING THE FILES YOU EXTRACTED....
8. Place the SPH-D720_IMM26_KE1_BOOTLOAD_signed.tar in the BOOTLOADER slot
9. Place the SPH-D720_IMM26_KL2_Modem_signed.tar in the PHONE SLOT
10. Place the SPH-D720_IMM26_PDA_signed.tar in the PDA SLOT
11. Make sure AUTO REBOOT & F. RESET TIME are checked and PRESS START.
12. If all goes well you will reboot into ICS 4.0.4
The attached screenshot below shows how your Odin program should be setup with the proper files in the proper spots.
Good luck!
Odin 1.81
ICS 4.0.4 package
Instructions...
Good luck!
