CWM is our custom recovery used to flash ROM, kernels and make backups.
Superuser is obtaining root to the device.
could i just pull the individual backup files from the individual apps off the sd card then put them back after the device wipe and restore them?
Paul627g, would you be able to write a script to relock the device if a person wanted? Or would I have to worry about that if I rolled back to Gingerbread to accept the OTA? It wouldn't relock the device or break anything would it?
I'm new to the whole unlocked bootloader/rooting thing (I didn't root though, just unlocked the bootloader).
Thanks!
No problem...
Really it won't matter leaving the bootloader unlocked at this point. But if you would like to lock it back up then here is the script below... Just throw it in that folder of tools I provided and click on the script from your bootloader screen.
Note: I would save locking the device back up until after you roll back to GB. Otherwise you will have to again unlock it to flash the GB images to rollback.
run_bootloader_unlock.zip (unzip and drop it in the IMM26D_Fastboot_Install directory)
So wait if use the cwm and superuser well I just be rooted? And will I still receive the official update?
Sent from my Nexus S 4G using Tapatalk
Question. Is this a new leak? Or the same leak as before?
So I'm pretty new to this whole thing and the instructions look pretty straightforward (thanks Paul627g!). I'll be coming from stock GB if I do go this route. My one holdup is sort of along the lines of 65fastback22 wanting to back up his app data...Is it possible to back up text (SMS) messages from the Messaging app & restore them on the newly flashed upgrade? That's about the only thing that's holding me back from updating right now (and having to do the full wipe) as I'd rather not lose all my Messaging history.
Are there any other things that those of you who flash/swap-out ROMS frequently find yourself missing or wishing you could back up/restore? Thanks!
Actually there is.
SMS Backup and Restore by Ritesh Sahu (get the right one ) from the Google Play Store (free app).
It will save your texts to your sdcard. You can then pull the backup file off your sdcard and throw it on your computer for safe keeping. They are located in a folder called SMSBackupRestore and you will see the given filename (backup) inside there.
It is actually a nice program, you can view and selectively restore messages along with other options.. I've used it many times in the past for my wife on her device.
For your other question, I have included brief instructions on how to "root" your device and install CWM (ClockWorkMod recovery) on you device using this package. This would then allow you to make backups and restores using programs like Titanium Backup or My Backup Root which you can make & restore backups of anything you like on your device. Apps, Data, etc... This then answers your question about saving & restoring stuff when swapping ROMs
