1. 6tr6tr's Avatar
    I've charged my phone tons of times since I put on ICS and it's never gone over 95% no matter what I do. But I found recently that if I'm talking on the phone (and it started at about 80%) while it's plugged in, it'll actually charge to 99%! (NOT the speaker phone, but regular phone where the screen turns off since it's against my face)
    Has anyone else noticed this?
    05-31-2012 09:11 PM
  2. presb4's Avatar
    But really the battery icon percentage is know to be less than accurate, so I would not worry about it.
    05-31-2012 11:43 PM
  3. docgoat1987's Avatar
    I was watching a hulu plus movie and i got it to 99 percent it was weird mine fluctuates between 89 and 94 normally with ics but it was weird also if i charge it on the car charger it will go to 100% hey that is not bad compared to my brother nexus which only charges to 34% and it says its charged i really dont like this battery bug also the charger bug too i can only use the samsung charger and for some reason the car charger which is an off brand i bought from the gas station
    Sent from my Nexus S 4G using Android Central Forums
    06-01-2012 05:23 AM
