1. 6tr6tr's Avatar
    Under the phone app->settings there's an option "Noise suppression" that was unchecked. I'm curious if anyone's tried it. How is it? Does it help (for the person you're talking to obviously)? Does it cause any issues?
    10-16-2012 11:48 PM
  2. mcantu's Avatar
    i'm not seeing this setting...
    10-17-2012 09:28 AM
  3. hlxanthus's Avatar
    I see in on aokp. I am not sure if it is available on stock ROM. I enabled it to see what happens.
    Sent from my Nexus S 4G using Tapatalk 2
    10-17-2012 10:09 AM
  1. Fitness Apps : Do You Really Use It and Does It Worked?
    By Dewangga Biasa in forum Health and Fitness
    Last Post: 02-22-2012, 07:37 AM
  2. Built-in USB tether: Does it work on Mac?
    By stoli412 in forum HTC EVO 4G
    Last Post: 05-09-2011, 06:47 PM
  3. Best to use wifi for froyo update, or does it matter ?
    By jasonvancouver in forum Verizon Droid Incredible
    Last Post: 09-05-2010, 05:49 PM
  4. Mass MMS. Does it work?
    By Mark_in_Tulsa in forum HTC EVO 4G
    Last Post: 08-20-2010, 09:35 AM
  5. How well does it work in low signal areas?
    By bigbot45 in forum AT&T Captivate
    Last Post: 07-21-2010, 02:22 PM
