I just picked up a Nexus today, and it already has build GRJ22, which I understand is the latest update.
I am sitting in my office in downtown San Francisco, where last week I was running my entire office network (we had just moved and had DSL problems) off of a Clearwire WiMax Hotspot. The signal was excellent and constant, and we consistently got speeds of 6Mb or more.
I have my Nexus in the same location. It will intermittently get 4G, but only what appears to be a weak signal (at most 10% of the time), and then the signal will go away. Presumably this is the same Wimax signal as with the Clearwire modem.
I figure OK, the 4G doesn't work, so I'll use wifi. In the very same place where I receive a strong and constant wifi signal on my laptop, and a strong and constant signal with a Virgin Mobile LG Optimus V, the Nexus is incapable of using the same wifi signal.
Even though I don't need wifi tethering, it's enabled by default on the phone so I figure I'll try it out. As soon as the wifi tethering is turned on, the phone stops receiving cellular data. Not only is there no tether to the internet, but no apps on the phone that need to access the internet can do so until the wifi tether is turned off.
I'll skip the usual commentary - other than to say this phone seems to have some serious problems.
