07-24-2011 11:06 PM
42 12
tools
  1. BlackHawkA4's Avatar
    You don't understand how I explained them or dont understand why they're the options?
    I really don't know why you'd want to have it sleep when off, especially since there's no visual message indicator on these phones...constantly clicking the screen on and off.
    Why they have the options. Wifi sleep is pointless IMHO.
    esoh likes this.
    07-07-2011 08:49 PM
  2. chud's Avatar
    Agreed.^^^
    esoh likes this.
    07-07-2011 08:56 PM
  3. sedracer's Avatar
    What are the settings you have to get that battery life?
    Sent from my Nexus S 4G
    Stock GRJ22/rooted with the stock kernel. Auto brightness, wifi is always on. Averaged 30+ hours easy.
    Flashed netarchy 1.3.4 stable cfs last night because i wanted BLN and i played with Voodoo color settings and i'm on pace for about 25 hours today so i'll probably be going back to stock kernel.
    I tried netarchy 1.3.4 bfs and had issues with the sd card not being mounted. I might try a matrix kernel tonight and tomorrow to see what i get with a bfs kernel. Ideally i'd like a stock kernel with BLN support and maybe Voodoo, thinking if i want that i'm going to have to compile it myself.
    07-07-2011 10:23 PM
  4. tsrich's Avatar
    i did 40 hours yesterday and am on track to hit that again today.
    set WiFi to never sleep, turned off widow animations and left the Facebook app installed but everything is turned off. Those three things seemed to bump me way way up. A little bit of the new toy playing has died down, but I've still be on the thing a lot because of all the Google + stuff going on.
    Where do you live that you have 40 hours in a day?
    07-08-2011 12:13 PM
  5. chud's Avatar
    Yeah it sucks, but just imagine the overtime pay.
    07-08-2011 12:49 PM
  6. ck2's Avatar
    My battery barely lasts for 4 hours...and that is having everything on low use. Every time I turn the screen on, it goes down a percentage. I have 3 batteries I carry around with me. It is pathetic. My display runs around between 75-83%
    07-08-2011 06:29 PM
  7. chud's Avatar
    That's just not right. Are you in a really bad coverage area?
    Anymore insight as to what you have running?
    07-08-2011 07:11 PM
  8. beedip's Avatar
    I have had my NS4G since launch day and I have been able to keep a consistent 12 hour charge throughout my day. I text a lot through the day, and keep my screen on max brightness too, so I could get even better battery life if I choose to make some sacrifices . I did install and currently use Juice Defender so I'm sure that will account for a lot of my charge, but overall I am really happy with the battery life. Try turning off your GPS settings when your not using a map application, I have a friend of mine who keeps his on with the same battery saving app, and it does make a significant difference.
    07-08-2011 07:24 PM
  9. BlackHawkA4's Avatar
    Something is terribly wrong there. You should really get that checked out.
    07-08-2011 09:46 PM
  10. adge4u's Avatar
    Can pull 14-20 hours out of my battery with minimal use. Hit the web and some games at night and a few texts and email during the day
    07-24-2011 12:04 AM
  11. ShadowKing's Avatar
    as you can see, a good 9 hours worth of battery. auto sync with G+, Gmail set to push, Google Music, and games.
    as you can see, i did plug it in for a while, but i then decided to see how far i could go with it.
    and after it hit %20 i tried my hardest to drain the battery. Full brightness, everything sync, GPS on, & watching a 30 minute youtube video. it still had 5% left so i just tried to kill it in everyway possible. great battery life in this phone.
    07-24-2011 04:18 AM
  12. dwaynewilliams#WN's Avatar
    I must be doing something wrong because the rest of you are getting exceptional battery life. I do keep gps ans wifi on all day. I also have the brightness set to auto. I email, text, stream music and video, and make calls and I generally get about 12-13 hours a day and I believe that is really good. I haven't gotten anything near that with any other device outside of my old BlackBerry Bold 9700. On the other hand, if I have to turn ecerything off to achieve the numbers that some of the others are getting than no thanks.
    07-24-2011 10:23 AM
  13. skinneejay's Avatar
    @DwayneWilliams Why do you keep GPS on all day? Unless I'm using navigation I don;t see the point as to keeping that on? still 12 to 13 hrs is good.
    07-24-2011 01:51 PM
  14. BlackHawkA4's Avatar
    GPS won't run/use battery unless your in an app that uses it. Unless the GSP indicator in the status bar is there it's not using battery. I leave mine all as well. 8-9 hours in my office with decent service. (Last 3 days I've been getting terrible service here) Outside with excellent service, same usage I hit 12 hours with 60% left.
    If your wifi is connected it's using eating battery. A lot. So turn that off. Unless you in a Wifi area and connected. where you'll get better battery life.
    07-24-2011 02:13 PM
  15. Verdes8891's Avatar
    I am on average pulling anywhere between 10-14 hours of battery a day on my nexus s. NOw this is with light usage during the day, and moderate usage at night.
    During the day i might have a few calls and a few texts and check the forums here and facebook.
    At night, lots of text's, at least double the phone calls. More forum lurking (lol), facebook, Google+, Google Music, and maybe a game or two to kill time.
    The way i got my settings.
    Wifi turned off when im not at home, turned on when i am at home.
    Background Data is turned on.
    Display brightness i have auto turned off and it set at about 35-40%, more then enough for me.
    Only to show some of the screen animations.
    I have Back up my data and automatic resotre set to on.
    GPS turned off.
    Vibration for typing on the keyboard turned off.
    Everything else is pretty much stock and i get through the day fine for the most part. Some days are worse then others depending on how much i get to play with it.
    07-24-2011 03:55 PM
  16. 6tr6tr's Avatar
    I'm getting awful battery life. i have brightness all the way down, GPS off, synch on half the time, off half the time, show some screen animations, vibration for keyboard off, wifi on at work/home, off elsewhere, static wallpaper (no live wallpaper).
    07-24-2011 10:18 PM
  17. Polish Prince's Avatar
    I get about 10 hrs before it needs sharging (fairly heavy use). I'm ok with this. I also prefer using the word sharge.
    Sent from my Nexus S 4G using Tapatalk. Round stinka lardum bardle doo.
    07-24-2011 11:06 PM
42 12
