When my BT earpiece is connected, visual voicemail will not play messages through it. If a message is 2:15 long, the scrub bar just flies through it as if it was only 1 second long. If I disconnect my earpiece, vvm plays messages properly. If I reconnect it, most of the time, the messages will play through the earpiece successfully. Of course, this behavior is annoying.
Anyone else experiencing behavior like this? Any solutions out there?
I'm using the Plantronics Voyager Pro+ BT earpiece.
Update: I'm THRILLED to report that I've found a way to fix this issue. The answer is Better YouMail (link). It is working flawlessly with by Bluetooth. Report back if you have success with it too!
