1. mkgomm's Avatar
    I am having an issue now with Sprint regarding the stock battery that came with my Photon. All of their online advertising lists the battery to be 1700 mAh. They insist this to be true. Motorola also lists the Photon to have a 1700 mAh battery. My question to all of you that wish to respond is what battery did you get when you purchased your Photon from a Sprint retail store or online thru Sprint. Mine is type HF5X with item #SNN5890A and clearly states 1650 mAh. I have read some past posts about the battery that indicated it to be 1650. Thanks in advance.
    10-12-2011 12:41 PM
  2. dorelse's Avatar
    Mine is also type HF5X.
    Reading the label is confusing it says:
    1650mAh min 6.3Wh min
    1700mAh typ 6.5Wh typ (this line is in bold).
    some Chinese writing
    1650 mAh
    So...I'm going to assume that its based on the 1700mAh rating on the label. I'd take a picture...but alas...need the battery for that!
    10-12-2011 01:07 PM
  3. Mike77's Avatar
    Thats how they all are, advertised 1700 but 1650 i guess, doesn't matter in the end prob the best battery life on this I have ever seen.
    10-12-2011 02:35 PM
