1. Arielle Gray's Avatar
    Sooo...I know this issue of Photon's not charging/ booting has been explored before but I can't find anything explaining this particular case.
    I was using my phone today and it plugged into a wall charger and it was charging fine. I took it off to talk on the phone but when I tried to plug it in again, I noticed the phone wasn't charging at all. The phone was on and fully functional but it was as if it wasn't recognizing the micro USB. When I got home, the phone died and now its impossible to get it to turn on again. When I pull the battery and plug the phone in, a White LED light comes on. But if I put the battery back in the phone, the LED light immediately goes off and stays off. I tried stripping a USB cable to give the battery a jumpstart but even after that, the phone wont turn on. PLEASE HELP!
    08-10-2013 01:16 AM
  2. Cellmeister's Avatar
    Hi Arielle,
    Sounds like the battery is NG.
    I would try another battery, if its the original battery they are rated for a little over 12 months of use, but can last longer.
    You can get an OEM Battery (stick with the OEM aka Motorola brand original type) on Amazon for around $9.00 last time I bought one (avoid fleabay).
    If you know someone else with the same phone ask to try there battery.
    Hope that helps!
    08-11-2013 09:21 AM
  1. Replies: 7
    Last Post: 11-28-2013, 02:41 PM
  2. Battery drain on AT&T GS3 with CM 10.1
    By harryg27 in forum General Help and How To
    Last Post: 08-16-2013, 01:37 AM
  3. Video playback on Kies
    By dytkd in forum Samsung Galaxy S3
    Last Post: 08-10-2013, 12:25 AM
  4. Cannot Complete 'Software Update' on my GT-S601? Please Help
    By Nabeel Farooqui in forum General Help and How To
    Last Post: 08-09-2013, 10:49 PM
