1. Pablo Mojica's Avatar
    Im gonna get a Galaxy Note 3 for Sprint soon and I want the 4k camera mod and multiwindow mod , what do i do to get this?
    12-26-2014 12:59 AM
  2. Rukbat's Avatar
    For a 4k camera in a Note 3, you remove the existing camera and install a 4k camera. (It's a hardware difference, so you have to change the hardware. You'd buy it from Samsung.)
    Multi-window? There are a few apps - one to add apps to the existing multi-window function, one to add more than 2 windows, probably others.
    As far as rooting, see the Sprint Note 3 forum on XDA Forums. I don't think you can yet if your phone is updated to 5.0 or higher. If it's still on 4.4.2, with a kernel date earlier than June 3, 2014, Towel Root will root it.
    12-26-2014 01:21 AM
  3. Meech_The_Katana's Avatar
    I have 5.0 and i rooted it with Odin.
    05-18-2016 10:13 AM
  4. Meech_The_Katana's Avatar
    Where can i download some different roms and kernels?
    05-18-2016 10:15 AM
  1. random crash and reboot problem
    By jpdaballa in forum Motorola Droid Turbo
    Last Post: 01-02-2015, 06:50 PM
  2. Anyone with a Nexus 9 LTE?
    By Dueyduck in forum Google Nexus 9
    Last Post: 01-01-2015, 01:14 PM
  3. Can I get some help diagnosing my Note 3?
    By mikenike104 in forum Samsung Galaxy Note 3
    Last Post: 12-26-2014, 01:24 PM
  4. I need help choosing security and cleaning software
    By PDX97229 in forum Motorola Droid MAXX
    Last Post: 12-26-2014, 09:52 AM
