1. DuStU's Avatar
    I still don't understand exactly how the lockscreen works. Is there a video that teaches you how to do it? Like just answering a text seems like a two step process. Any help with this would be awesome!
    05-17-2013 01:14 AM
  2. Hypochondriac's Avatar
    Can you be more specific? What problem are you having? Once you lock the screen you can't do anything until you unlock it
    05-17-2013 09:31 AM
  3. DuStU's Avatar
    This is not true you can add items on the lock screen that you scroll to the right and left you can also respond to a text but I have problems opening straight to text since I dont know the correct gesture to open it. The old lock screen (s3) you just clicked on the text and you where sent to text this seems like a two step process I am not 100 percent clear on.
    05-17-2013 02:59 PM
  4. vferrari's Avatar
    I too would like the answer to how to open texts from the lock screen. I'm just winging it and sometimes I can get it to unlock into the text thread and other times I can't even get the lock screeen to unlock until I cycle the power button to bring up the "default home" lock screen.
    05-22-2013 10:18 AM
  5. dougltc's Avatar
    I can't figure out how to enable adding widgets on the lock screen. The 'favorite apps or camera' option is grayed out. And on the lock screen long pressing does nothing. Help!
    05-23-2013 09:49 AM
  6. cjones's Avatar
    If you get a text and it shows a small rectangular box showing who sent the message and a few of the words from the text, you simply touch that box and then a larger sort of grey box appears on the bottom of the screen. Place your finger on that box and swipe across. It will bring you directly to the text message.
    As for adding programs on the lock screen- open your lock screen and place your finger on the far top left of the screen and swipe to the right. You will see a plus(+) button. Hit that button and it will give you a list of apps/widgets you can load onto theses screens to be able to use without unlocking your phone. It is a little tricky and if you swipe to the left from the lock screen it will take you right to the camera.
    I don't find these app/widgets as useful on TouchWiz as I did on other ROMS I have used with my last phone.
    Good Luck!
    05-23-2013 10:24 AM
  7. GiantJay's Avatar
    You have to activate multi widgets in the lock screen settings before being able to add anything there.
    Sent from my SPH-L720
    05-24-2013 06:34 AM
  8. asdfasdfgasdfadfs's Avatar
    Correct me if I'm wrong, but all this only works if you are not using any lock screen security like Pattern or PIN, otherwise these will not work?
    06-10-2013 11:40 AM
  9. GiantJay's Avatar
    Yes. Although I think in the new update this might be fixed, is what I heard.
    Sent from my SPH-L720 using Tapatalk 4 Beta
    06-11-2013 02:27 AM
  1. Anyone remembers how to edit the lock screen short cuts?
    By Ledward1245 in forum HTC EVO 4G LTE
    Last Post: 02-08-2013, 12:33 PM
  2. How do I learn how to use all the features?
    By barskin in forum Samsung Galaxy Note 10.1
    Last Post: 09-23-2012, 11:07 PM
  3. Need help on how to root. im a noob
    By solost26 in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 01-31-2011, 11:39 PM
  4. Do you need a cable box to use the Revue?
    By Dj_sQuiGGz in forum Google TV
    Last Post: 10-28-2010, 05:34 PM
  5. Do I need a Gmail account to use the Evo?
    By PurpleGuitar in forum HTC EVO 4G
    Last Post: 06-03-2010, 01:21 PM
