Hi guys I seem to be having the same problem since I put in the sd card and its the 64g sd card. Every picture I take is corrupted and disappears, the only way they save so I can see them is If I take a pic then go in and screenshot it but thats ridiculous!!!!! Such a fab phone and this problem cant be solved?? Any one go into the shop and ask for advice?
Possible FIX for the SD CARD PROBLEM !
I've had this exact same issue on my S3 twice, and today my wife had it happen on her phone. Pics turn to bw icons, mp3s die, and visiting the gallery or music player hangs for about 60 seconds. I said to heck with it and formatted my SD card and it displayed messages for "unmounting" then "erasing" then, pow, my files were all restored.
The first time it happened, I thought that maybe Lookout did and instant restore, even though I only have the free version. But the second time it happened, the fix worked again, and the files appeared immediately, too quick for a restore. Today my wife's phone had the same problem so, despite her pleas to not format her SD card, I did so and all her files came backi know that this cannot happen.
I know that by all rights it should have erased all my files. But I've seen it work three times now.
I'm no expert, so I don't want to recommend that you try this on your phone. But if your files are already corrupt and you've got nothing to lose, give it a try.
I contacted samsung and this is the reply. Ive done it and so far so good, except the corrupted files are still corrupted, but I can see the pictures I'm taking now.
1) From the standby screen, tap Applications.
2) Select Settings.
3) Select Storage.
4) Select Format SD card (Please note: If this option is disabled, select the option to Unmount SD card first)
6) Select Erase everything.
7) After the card is erased, select Mount SD card.
I am having the same issues. The sales person at the Verizon sure took my ad card from my old phone and put it in my s4. No problems for a month then I notice sine if my pictures are not showing up and have a"broken" picture image instead. Go back to the Verizon store and ash what is going on. They said I must have used an app to move them and now they are gone. I did NOTHING to my existing pictures. I took photos is all. Some of my older pictures are gone as well as ones I have taken since getting the phone. They told me to go to Wal-Mart and remove the card and get a CD made of the ones that were still good. I have not done that yet as I did not like their answer-they didn't seem like they knew what they were talking about. So I started looking for answers and have found this thread. Not sure what to do now?! Some of the pictures are of my son from boot camp! Help please
I have the same problem with my new samsung 64gb micro sd class 10 card when used with Galaxy S4. My photo files corrupt and recently video files too. This is really annoying. At first i thought i had a faulty micro sd card, but after going through this forum, it doesn't appear to be the real issue. I had formatted my micro sd card and tried but in vain. I felt one should be really lucky enough if the file hasn't corrupted. However, when i tried copying my backup photos from computer, i did something that retained photos on the card but that is not the real solution though. And what i believe to be is since 64gb + 16gb internal memory is a too large memory and file addresses could be anywhere located on the card, i tried copying very few photo files at a time (around 60-70, any lesser chunk would be even good) instead of copying all files at a time and overwhelming the memory card. Then i went in and opened my photo album in memory card (after each chunk of data copy) allowing it read my photo files properly as i scroll all the way down to check all my photos are displayed properly without breaking or damaging. I did this tedious process and was able to copy around 1000 pics properly. I know all this is unnecessary stuff that i should not really be doing but at least i was able to copy few files. I then started believing that i should not overwhelm my memory card or processor to read files. This is not a guaranteed solution because the problem has not wiped off completely. I would be happy enough to find some solution on this forum. I don't know if its a problem with Galaxy S4 or any android phone or simply micro sd cards but whose ever it is, somebody has to find a root cause and provide customer satisfactory solution.
