Sprint Galaxy S4: "Android System" is draining my battery since I updated to KitKat
dllebandroid
18
Before I updated yesterday my phone had good battery life, and the wake time was under 20 mins in a 17hr-36hr span. I could literally have the screen on and play music off the google play music app and the phone would still be asleep according to the battery monitor on the phone. Now if i turn the screen on or play music the phone awake and cannot fall asleep, but when the screen is off and no music is playing then the phone falls to sleep. I have the phone unplugged @ 91% for almost 40 mins and the screen is taking 51% with 26 mins SOT, android system is taking 26% running for 7 mins, android OS is taking 9%, media (which always starts out at the top since the update) is taking 6%, GSM battery monitor is taking 2%, google play services is taking 2%, and com.android.systemui is taking 2%. Can someone please explain to me why android system is now draining my battery way more than it should?
bdmridgback
499
32
Re: "Android System" is draining my battery since I updated to kk
Mine is the same since update.
Android System and Android OS are sucking the battery
Sent from my SPH-L720 using AC Forums mobile app
dimm0k
71
not sure if there's an easy fix for this, but I was reloading the MK2 ROM over the weekend, as well as wiping before finally getting things just the way I wanted and then loading all my settings and apps. unfortunately I had to wipe again last night because my battery was draining like a whirlpool all day yesterday despite putting the phone into airplane mode. culprit was also the "Android System" using the most battery as listed in the Battery section. after doing a wipe and reloading my crap last night I've been back in business since! highest battery user now is the screen, which I believe is normal.
dllebandroid
18
bdmridgeback Thats terrrible. I don't know what is causing Android System and Android OS to keep the phone up so much
dllebandroid
18
I don't think that there is one. I wish apps like "wake lock Detector" worked on KitKat
Shane Kinsch
Same here (Sprint)... a temporary fix was the completely disable Google Now (as suggested in other forums) but that didn't last long. I actually had my phone plugged in last night (20% remaining) and it drained completely while it was plugged in! It shutdown / powered off because it had no juice, then started to charge.
I believe it's not going into deep sleep. Possibly because of the bluetooth connectivity with my Galaxy Gear, I dunno.. I doubt it's the Gear because I'm seeing a lot of posts about the battery issue after the KitKat update.
GSam Battery Monitor --> msm_hsic_host wakelocks is taking up a considerable amount of time preventing the phone from going into deep sleep.
dllebandroid
18
deleted_wake_locks and man_hsic_host wakelocks are preventing my phone from going into sleep. I don't even know what it causing them to awake the phone.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
GSam battery monitor still works on KK I believe
Sent from my Galaxy S4 running SlimKat 4.4.2
dllebandroid
18
It works to a degree. I need the partial wake lock that "wakelock detector" can do. Google change the permissions in KK so i would have to root my phone to get that feature.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
I thought it worked without root. In that case it's the same as WLD. Good thing I have root :)
trublond
20
What are you location services settings. I use to have wifi/cell/gps and my Android System was very high and I had poor batter life. I turned wifi/cell off and I am just using GPS and it has greatly improved.
dllebandroid
18
my location services are turned off.
fppc
4
My S4 received the Kit Kat update and once it rebooted the lock screen was freezing and within 1 hour the battery went from 90% to 17%! I noticed the GPS icon at top left was flashing rapidly as if it was unable to locate reference points. I switched off the GPS and all seemed well as long as it remained off. I use hands free with a Bluetooth headset when driving so the first time I made a call the "driving mode" activated the GPS again and the phone was back to messed up. The only way I have been able to correct the problem is to ensure GPS is off, hands free is off and then pull the battery.
I did stop by a Sprint tech store and the tech was very helpful. He learned a bit with my experience and he informed me of all the other issues. Sprint has instructed the techs to NOT attempt to roll back the system as the phone will brick. Sprint and Samsung are supposedly working on a patch and as long as you have reported your issue to Sprint you should receive a patch within a coupe weeks. If you have not yet upgraded to Kit Kat my advice is DO NOT DO SO until the issues have all been resolved. Fortunately my wife's S4 did not receive an update notification until a few days after mine so we know not to proceed. With luck this will be corrected quickly, all else seems to work as long as the GPS remains off.
dimm0k
71
interesting... how will we know the issues are fixed if we don't update to Kit Kat?
dllebandroid
18
How do you know if Sprint and Samsung are working on a patch?
Tsukiyomi
153
7
Add me to the list. My phone's been exactly the same. I was loving the battery life on this until Kit Kat. Now rather than 1 1/2 or so days with normal use I'm getting about 9 hours. My wife did the update and hers is even worse.
ToddK
238
Ditto - the first 2-3 days were okay , but then the wheels fell off and I'm getting 8-9 hours tops...
...and the kernel is drawing 86-89% at times... used to be 30-40%
Sent from my SPH-L720 using Tapatalk
ToddK
238
The kernel is now up to 91%!! Battey life has gone from great, to, bad, to horrible... but no single app is drawing over 2%... Wish I could figure out what was destroying the battery -
Markizta
