Okay, well anyway I have had my Atrix since it was first released almost.
A couple of weeks ago the phone was working fine, and then I was browsing the web on it and I get the dreaded Black Screen of Death. At that time the phone was super hot on the back. I popped the battery out and back in. Everything seemed fine for a week or two.
Now, my phone when charging via power outlet or any method never reports 100% or goes to saying fully charged. Instead, it gets stuck at 90%, and acts like it still needs charging. It also gets slightly warm when charging now. When I reboot the phone though, it reports 100% fully charged. The battery also does not seem to be lasting for as long as it used to. I used to get 2.5 - 3 days when I never used it aka on standby the entire time. Now it only gets about 10hrs even when fully on standby.
Another odd thing, is now when I reboot the phone the notification light continually blinks green when the phone is in standby / locked. However, the minute you turn the screen on it stops. The thing is, it used to never do that, and there are also no new notifications when doing it. It will finally stop once the phone receives a real notification from Gmail or another application.
I haven't installed any new apps on it, and it is currently running the latest build available to the atrix so gingerbread. The phone is set to night time battery saving mode. Also the screen brightness is set to the dimmest level.
Any advice would be appreciated. I have a feeling it is the battery dying, but it could technically also be my phone. It could have something to do with the BSOD I had.
Thanks,
Metric
Thanks,
Metric
