1. nate360's Avatar
    trying to install di11i's new rom and rom manager say i theres a n error when it trys to download my recovery? PLease help! i cant run on stock for lmuch longer!
    -nate360
    02-05-2011 02:44 PM
  2. DrDubzz's Avatar
    See this thread for how-to [GUIDE] How to Install a custom ROM *NOW WITH VIDEOS* - xda-developers
    Here are the highlights (DL links in the above thread)
    step 2: Root the phone.
    If you are already rooted skip this step. Note that rooting BEFORE using ODIN does not mean you are still rooted.
    1. To begin, mount your phone by plugging it in to the computer (you must have the drivers installed in step 1.1)
    2. Go to the root file in the downloaded folder. It is called root.zip. Drag it onto your phone's root directory.
    3. Rename the root file to update.zip and then turn your phone off.
    4. Unplug your phone and hold down both volume buttons and the power button until a strange menu with blue items pops up. This is called the recovery menu.
    5. Use the volume keys to scroll to 'reinstall packages' and press the power button to select. When it is done you will be rooted and then you can just scroll to the restart phone menu item.
    step 4: Install clockwork recovery.
    1. Go to the download folder and rename clockworkrecovery.zip to update.zip. Mount your phone and drag the update.zip file into the root directory. It is ok to overwrite the update.zip you used before. When it is done copying turn off your phone.
    2. Unplug your phone and hold down both volume buttons and the power button until a strange menu with blue items pops up. This is called the recovery menu.
    3. Scroll using the volume buttons to the menu item titled "reinstall packages" and press the power button to select.
    4. Your phone should restart and you should be at a green menu. Continue to step 5.
    I don't think I've ever installed CWM with ROM manager so I couldn't help with that.
    Read through the post and follow the steps, you'll be good to go.
    Also, Di11i's new ROM is killer, I love it
    nate360 likes this.
    02-05-2011 03:20 PM
  3. nate360's Avatar
    where do i get the clockwork recovery.zip?
    02-05-2011 04:33 PM
  4. nate360's Avatar
    Dude i love you
    02-05-2011 04:50 PM
  5. DrDubzz's Avatar
    Dude i love you
    easy killer lol
    yeah, it's all in that post. if you run into anymore questions feel free to ask
    02-05-2011 04:53 PM
  6. InnocuousScreenname's Avatar
    Yup. Seems folks are having issues with ROM Manager. I found that "How to" thread and discarded ROM Manager a while back. (still a great app, though)
    I just manipulate clockworkmod manually.
    02-05-2011 09:29 PM
Tags for this Thread
