In going into the wifi control panel at the bottom there was " Wifi Direct ". I was hopeful that one of the more Seasoned or experienced members of this forum could explain. What it is, how it is different than normal n-wifi and its relationship or impact on the Galaxy Note2 and its use.
Im using a Linksys Extreme gamer N Router, 3 antennas on it if that helps. Looks like it came from star trek.
Thank you in advance.
