Anyone have some suggestions for a car mount to use the GPS capabilities to their fullest? Looking for a dash or window mount that would work with a case.
Todd
Todd
I bought this one and so far I like it. It holds good and doesn't shake that much
Amazon.com: iOttie One-Touch windshield and dashboard car mount for Galaxy Note 2: Cell Phones & Accessories
Amazon.com: Mountek nGroove Universal CD Slot Mount (Black): Cell Phones & Accessories
I highly recommend this one. Review: Cobra Universal Cigarette Lighter Mount - BriefMobile
- Works with any device
- Can get it with cigarette lighter or suction cup mount
- The head is interchangeable with the iGrip brand of mounts
- The gooseneck is strong and adjustable
- The sticky surface works great and doesn't leave residue at all
- When the stickiness gets dirty, just wipe it off with water and it's good as new
- Since there are only two support prongs at the bottom, it doesn't interfere with any ports
- $20 or less at multiple places on the web
I have one and won't use anything else now. Here's a picture:
http://briefmobile.s3.amazonaws.com/images/articles/100_1750.jpg
If you don't mind paying a higher price www.proclipusa.com offers really nice mounts.
I'm actually using a adjustable holder that I have had since the iPhone 4 it was design for use with iPhone with a case, but it works for virtually any device. I have just had to buy a new mount when I get a new vehicle.
Sent from my SAMSUNG-SGH-I317
The Amazon description says the suction cup works on textured dash surfaces. Can you confirm if it does? This will make or break it for me.
I have not used it on the dash as both of mine are textured. I've used on the window only and it holds really well.
Edit: Do the side fingers cover up the volume or power buttons?
