I went with a Panavice dash mount and slapped on a ram mount with the x grip. Very sturdy and infinite positioning. Will take puctures tomorrow.
Update: Dec. 18, 2012...
So I attached the PanaVise to my dash like so...
Then I attached a 1" Ram Mount ball to the PanaVise...
I then attached a Ram Mount short arm to the 1" ball...
Finally, I attached the Ram Mount X-Grip to the arm...
Overall, there is some shaking, thanks to my bumpy suspension, but the grip is rock solid and can be used for almost any other device. The X-Grip fits the Note 2, but barely. I've used it with a standard silicone case, TPU case and they've both fit. I'm not sure if a big case (like Otterbox Defender) would fit.
Sent from my Note Deuce using Tap-uh-talk
