1. bmkpoe's Avatar
    So im on my 3rd phone and 4th sim card and at&t has no idea what the problem is. It started a couple weeks ago.....my phone takes about 20 secs to connect and sometimes it doesn't even connect, it just drops the call. And when someone calls me they can't get through, it rings three times on their end then goes straight to a busy signal. I really like the phone but if it doesn't make calls or receive them is useless to me. I've never had this happen on any phone, and it doesn't happen on any of my other lines.
    I'm so upset that i might need a different phone.
    Any ideas?
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    12-18-2012 05:25 PM
  2. DroidXcon's Avatar
    Any ideas?
    Why didnt they replace it? I have the verizon version and i make calls with AT&T sim with no problems.
    12-18-2012 05:36 PM
  3. Slingbox's Avatar
    Wow three swaps that's intense
    The radio in ATT version is strong....as matter of fact yours is the first post Ive come across were radio performance reported not so stellar.
    Did you purchase from Store? , If so maybe a bad batch. Ive ran into those with Sprint GS2 Epic 4G Touch & Blackberry Tour in the past.
    12-18-2012 05:38 PM
  4. bmkpoe's Avatar
    I bought it from best buy. I have yet to read any issues with the note which is why i was concerned.
    And best buy had replaced the phone...this is the third handset I've had.
    12-18-2012 05:44 PM
  5. Slingbox's Avatar
    I would speak to manger ask for swap when next shipment arrives, If he fails to work with you go to different Bestbuy location do swap & keep fingers crossed its not a part of bad shipment.
    If the above fail to provide positive results call bestbuy 1-800.
    If worse comes to worse you can always cancel contract if your within 14 days of purchase refund up and go to ATT Corp store , Amazone.com etc & make the buy
    12-18-2012 06:07 PM
  6. Phoneguy108's Avatar
    Yes this seems like good advice.
    I am sorry for all your troubles with the phone bmkpoe
    12-20-2012 10:29 AM
  1. Problems with my Droid X
    By ramtwins in forum Motorola Droid X
    Last Post: 08-23-2010, 10:34 AM
  2. Replies: 2
    Last Post: 08-11-2010, 03:02 PM
  3. Default clock widget is wrong... problem with my GPS or something?
    By BriMcFly88 in forum Verizon Droid Incredible
    Last Post: 07-11-2010, 11:15 PM
  4. A few little problems with my Droid. I call upon you!
    By GenericMessage in forum Motorola Droid
    Last Post: 02-03-2010, 07:34 AM
  5. Problems with my email
    By jdaly in forum Motorola Droid
    Last Post: 12-28-2009, 08:29 PM
