zocipro
I still have problem with a AUTO rotation as especially testing on the images..Did anyone find real solution or need to check hardware sensor or something ?
Go to Phone app -> Click the Keypad on top -> Rotate -> Fixed!
I have to do that once or twice a week ever since I updated to 4.1.2.
Ok. I tried everything suggested here.
The only thing that fixes the issue as well as prevents it from happening is turning Auto-Brightness ON.
I know it sounds unrelated to the problem but it works!
Weird bug!
Note: You can still use 'Velis Auto Brightness' app to set your prefered brightness while the system auto-brightness is ON. Works perfect and auto-rotate keeps working!
can somebody explain detail for this step :
"Go to Phone app -> Click the Keypad on top -> Rotate -> Fixed!
I have to do that once or twice a week ever since I updated to 4.1.2.''
i dont understand where is 'phone app' > where is 'click the keypad on top' > where is 'rotate'
Already try to check Auto Brightness before but nothing change.
When i go to keypad on left side and i turn my phone to landscape position screen not rotate.
After rebooting, the auto-rotate will work, but after a few days it'll stop working, even with the toggle turned on. All sensors were fine. Sometimes apps will rotate into landscape mode and stay like that until I turn off auto-rotate. Smart rotation is turned on, but before the update, auto-rotate has always worked even with it on. So I'm inclined to think it's just a software problem.
Rebooting will solve the problem, but it'll come back after a few days. Is anyone else experiencing the same problem?
