1. insertnickname's Avatar
    Hello,
    I just got the Note 2 and it seems OK, however, coming from the iphone, there are several areas that it seems inferior. I have mentioned my problems with group texting and hotmail server-side searching, which doesn't have a free and seamless fix. What I'm wondering is, I have set up my visual voicemail and it works through the google voice application and I can get it to work through the AT&T visual voicemail application as well just fine. I would like to know if there is a way to make it so that I can push the voicemail icon in my dialpad to have it go directly to my visual voicemail instead of dialing into my old-school audio voicemail. This seems like a simple thing to do, and I don't know why there are so many little things that just can't be integrated like the iPhone, but I just would like things to be seamless. I understand I can open up the visual voicemail application and accomplish the same task, but I would like to automatically go to visual voicemail after I press the button on the dial pad, otherwise the button is just useless, because I would never use the old school voicemail method. I read some instructions online about doing this through google voice, and clicking the button that integrates it into the dialpad, but to no avail. Not only that, when I go into dailpad/callsettings/voicemailservice and try to select google voice as my service, it gives me an error. I know I can do this by manually entering in the phone numbers and it works, but I just don't know if this error is preventing google voice from integrating into the dial pad as it says it can from these instructions: [HOWTO][ICS][JB] Visual Voicemail Integrated via Google Voice - xda-developers Please let me know if there is a way to get this stupid button in the dialer to do connect to my visual voicemail.
    Thank you,
    01-12-2013 02:20 PM
  2. JayRatliff's Avatar
    I too was an iPhone user before seeing the light!! I'm sure one of the devs over at XDA could look into this and see, but at this time I do not know of any "shortcut" in order to redirect button press to another application.
    I'll do some digging around.....
    01-12-2013 02:26 PM
  3. MatroxD's Avatar
    Hello,
    Thank you,
    Actually and not sure if what your asking is the same, but I actually use att messages. It is the only thing I use by att sand that's only because out works well for me.
    Sent from my GT-P3113 using Tapatalk 2
    01-13-2013 01:12 PM
  1. please help im stuck at bootloader screen!!!
    By jayboy005 in forum Inspire Rooting, ROMs, and Hacks
    Last Post: 11-10-2012, 09:04 AM
  2. HTC One X (AT&T) Stock Rom Issue... Please Help
    By mr.vladzki in forum HTC One X
    Last Post: 06-23-2012, 11:49 PM
  3. Please Help. Unlocked Nexus One stuck at X
    By googol in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 06-08-2011, 10:01 PM
  4. original and repeating voicemail notification help please
    By ShaggyKids in forum Verizon HTC Thunderbolt
    Last Post: 03-30-2011, 10:29 PM
  5. Please Help - Phone stuck at M screen
    By kizer8 in forum Motorola Droid X
    Last Post: 10-10-2010, 10:29 PM
