1. tstens22's Avatar
    How is the battery life on the Note 2. May have already been asked, but couldn't find the answer.
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
    01-24-2013 02:39 PM
  2. Scott Kenyon's Avatar
    I haven't charged since last night before 9PM. It's almost 4PM now. Sitting at 52%. My battery meter says 12 hours of life left. Long story short, it's phenomenal.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    01-24-2013 02:46 PM
  3. aaronbuescher's Avatar
    for me its not crazy long, but I am always surfing the web and such. When I had my Galaxy nexus I needed two batteries to get me thru the day. With this one I only need one.
    01-24-2013 02:55 PM
  4. jlh73's Avatar
    I'm usually at about 16 hours with about 20% battery before I plug it in with moderate use.
    01-24-2013 05:27 PM
  5. BeRich's Avatar
    With lighter use:
    Otherwise I average 17+ hours if I'm constantly using it.
    01-24-2013 06:13 PM
  6. Scott Kenyon's Avatar
    Just to update, still haven't charged her up. 39% remaining. Empty in 11.5hrs. I haven't been going nuts with it today.
    01-24-2013 06:16 PM
  7. ItsaRaid's Avatar
    With lighter use:
    http://i1244.photobucket.com/albums/...7-15-36-31.png
    Which font are you using? What apps do you have disabled if any and do you leave wifi on all the time?
    Thanks
    01-24-2013 06:21 PM
  8. BeRich's Avatar
    Thanks
    I'm rooted running CleanROM SE for AT&T. I have an app installed called AutmateIt that disables the WiFi when it's not connected to my home network (i.e. I leave the house to go somewhere, but forget to turn off WiFi on my phone to save battery, that's no longer a problem with this app installed). The font is from an app... Font Installer (Root) by JRummy Apps Inc. and the font itself is "Romance Fatal Serif". You can install the app, download the font, set it, and then uninstall the app and you should still have the font. As for apps I have disabled, I never run GPS or Bluetooth (I have no reason to). Other than that, I don't really have anything disabled. I installed System Tuner Pro a few weeks ago and "froze" a bunch of apps and messed with the CPU and ended up bricking my phone, so I'm staying away from that app now because I obviously did something wrong.
    01-24-2013 10:27 PM
  9. kbd517's Avatar
    I can go almost 48 hours, with pretty heavy use (not watching videos) leaving 4g and syncing on *most* of the time. I typically charge each night, and by the time I do, I'm at roughly 50% after 17 hr days. However, I also use the go task manager and go battery manager apps. They work *very* well for me.
    02-04-2013 10:29 AM
  1. Improving Battery Life on Your Android Device
    By ERDude in forum HTC Hero
    Last Post: 09-07-2013, 12:03 AM
  2. Terrible, terrible battery life on the Note 2.
    By Shirodx in forum Samsung Galaxy Note 2
    Last Post: 01-25-2013, 02:00 AM
  3. How is the battery life on the Note 10.1?
    By rkeenan in forum Samsung Galaxy Note 10.1
    Last Post: 01-18-2013, 12:26 PM
  4. Video: how to increase battery life on your N1
    By mbranscum in forum Google / HTC Nexus One
    Last Post: 05-03-2010, 05:39 PM
  5. What's the battery life on this?
    By sekser in forum Google / HTC Nexus One
    Last Post: 03-15-2010, 04:36 AM
