1. misachan's Avatar
    hi
    there is a problem Im facing with my note 2
    my screen (display) frequently light by it self ( like every 5 minutes ) I tried rebooting, closing all internet connection ( mobile data & wi-fi ) , also I tried closing all app...... all that without any use & it affecting my daily battery usage
    If anyone can give me any advice.......thnx
    04-11-2013 03:36 AM
  2. spagman's Avatar
    Go to " menu / system / motion" and turn it off
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    04-11-2013 04:10 AM
  3. So Cold's Avatar
    You shouldn't have to turn every motion option off. It's probably the quick glance feature. What's on the screen when it turns on?
    Sent from my Note 2
    04-11-2013 10:34 PM
  4. spagman's Avatar
    I gave him/her the general instructions.. From there it should be easy to figure out.
    04-12-2013 01:10 AM
  5. misachan's Avatar
    tried that nothing changed.....
    04-12-2013 05:47 AM
  6. misachan's Avatar
    Sent from my Note 2
    the quick glance motion is already off.... I tried turing all the motion off .....nothing change..... and it turns on on the lock screen.......it keeps turn on & off on & off
    - - - Updated - - -
    04-12-2013 06:06 AM
  7. rabernet's Avatar
    Are you getting text messages when it's turning on?
    Sent from my SCH-I605 using Android Central Forums
    04-12-2013 06:08 AM
  8. misachan's Avatar
    no.....not even any notification
    04-12-2013 06:16 AM
  9. So Cold's Avatar
    Maybe a defective button or something, I would take it back
    Sent from my Note 2
    04-12-2013 07:28 AM
  10. thatdidnthurt's Avatar
    Did this issue ever get resolved? I have a Note 2 as well and have the same issue. Just a thought to the original poster - do you have Double Twist installed? if so, are you running AirSync and have DT open on your computer? I am starting to see a pattern with those parameters. Maybe an app that sync back to the computer, when it "checks in", the screen comes on....just a thought. I am definitely open to suggestions cuz it's getting old.
    04-17-2013 08:34 PM
  11. misachan's Avatar
    when I rest the mobile it stopped doing that....I think it was one of the app or something
    but I did notice that when I open the lock screen to unlock the mobile the screen wavers...... I really dont know how to explain this but I dont know I feel that there something wrong in the screen
    05-03-2013 06:45 PM
  12. Phoinx's Avatar
    I'm a victim of that too, even with all the Motion stuff turned off.
    I got AirDroid installed, but even with wifi turned off I still got that "slow blinking" screen.
    Maybe the screen really turns on when some app running on the background does something.
    My screen turned on now and the only thing I can see is a spam/update line in that menu screen (under "ongoing" or something), generated by some stupid game.
    However, even after clearing that message up, the screen still keeps turning on and off...
    So... I don't know really. looking for a solution too. ><
    09-14-2013 03:32 PM
  1. touch screen problems
    By mysticlife in forum HTC Droid Eris
    Last Post: 09-14-2010, 08:42 PM
  2. Screen Problem
    By netnurse#AC in forum Verizon Droid Incredible
    Last Post: 05-01-2010, 06:13 PM
  3. 2 weird touch screen problems
    By sethjk in forum Motorola Droid
    Last Post: 03-16-2010, 02:43 PM
  4. went into test mode now have screen problem
    By ehands in forum Samsung Moment
    Last Post: 12-30-2009, 09:26 AM
  5. Screen Problem. Anyone else have this?
    By MattJr35 in forum Samsung Moment
    Last Post: 12-16-2009, 06:47 PM
