1. Eric3272013's Avatar
    I just got my Note II. I found it is not convenient to make a call. If I choose a contact from the contact list, the next window is the vCard of the person, I have to tap the phone number to place the call even the person has only one number in the vcard. Even in call Logs, from the list of persons I called, if I tap a person, still the vcard is shown, you have to tap the phone number to call. Is there any setting for direct calling without tapping twice?
    Thank you.
    04-17-2013 01:31 PM
  2. FitMomXtine's Avatar
    Thank you.
    Congrats on your Note 2
    I believe if you are in your contacts list and you choose a contact.. I think it's swipe right on that contact to make a call and swipe left to text them Hope that helps and answers your question.
    04-17-2013 02:10 PM
  3. Eric3272013's Avatar
    Thank you so much for letting me know the secret!
    04-17-2013 02:22 PM
  4. FitMomXtine's Avatar
    You're most welcome!
    04-17-2013 02:29 PM
  5. rankar7's Avatar
    Thank you.
    go to system settings > motion > direct call (check the box)
    so if you're looking at a contact you want to call, just place the phone up to your ear and it will dial the number automatically.
    04-17-2013 03:14 PM
  6. eds817's Avatar
    As long as you're not don't have Google Voice or MagicJack or some other app installed unless you elected to use one choice all the time.
    I have Google Voice and elected to choose every time.
    04-17-2013 03:41 PM
  1. Is there no shortcut for the Downloads app or am I crazy?
    By notsonic in forum HTC EVO 4G LTE
    Last Post: 01-24-2013, 09:20 PM
  2. Rooted. Call volume too loud. Is there a way to change volume range?
    By DigitallyChallenged in forum Verizon HTC Thunderbolt
    Last Post: 05-13-2011, 09:55 PM
  3. Replies: 7
    Last Post: 07-13-2010, 05:55 AM
  4. Replies: 3
    Last Post: 01-12-2010, 07:22 AM
  5. Is there anyway to make the notification sounds last longer?
    By Theodore55 in forum Motorola Droid
    Last Post: 12-04-2009, 10:04 AM
