1. Btomlin75's Avatar
    I have had an intermittent problem with my usb connector since I received my GN2, unlocked ATT version. Periodically my phone will not recognize the usb port, not just for connecting to the pc but also for charging. I let the phone sit plugged in and it might start charging, I turn it off and leave it plugged in and it might start charging, I plug it in again and again and it starts charging. The same thing happens with the connection to the pc. I have no firm handle on the cause or the cure but sometimes I plug in and it works and other times it does not work. Last time it stopped was after 8 apps did updates. Any ideas. SGi317, android 4.1.2,
    Well May 14 the unit stopped charging again, so it's gone back to Samsung since they assume that it's a hardware thing. Hope it doesn't take too long.
    05-11-2013 06:05 PM
  1. Problem with USB debugging using Nexus 4 toolkit
    By badbrad17 in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 07-26-2013, 06:13 PM
  2. Need to safely remove hardware or just pull out USB?
    By pcguys in forum Samsung Galaxy S3
    Last Post: 03-04-2013, 04:50 AM
  3. Problem with USB
    By mike52599 in forum AT&T Galaxy S II
    Last Post: 06-27-2012, 09:58 PM
  4. Problems with USB Mass Storage
    By FILIPINOY79 in forum Samsung Galaxy S II Skyrocket
    Last Post: 01-15-2012, 11:52 PM
  5. Hardware or Software issue with charging?
    By tlacour in forum Verizon Fascinate
    Last Post: 05-23-2011, 07:20 PM
