1. KTTB's Avatar
    So I just got this phone today from ebay and it doesn't come with the original charger , I have phew cables from my old lg and others phone which using the same port , the thing is when I try to charge it , I plugged in and the screen will not turn off , I tried to press the power button but a few seccond it turned itself back on, it just keep doing it and sometimes it even changed to dock mode and then disconnect even though it still plug in , HElP , what do I do now ?
    07-13-2013 07:56 AM
  2. prepaidguy9081's Avatar
    Might be that you have a 5 pin cable n not the new 11 pin mtp cable
    Might be that screen on while charging is tiked in settings idk where it is off hand, go hunting
    If thats notbit try a freinds power brick if that solves replace yours
    If thats not it, buy a new cable off ebay for 1 dollar. Anything micro usb for a sgs3 or later
    Sent from my SGH-T889 using Tapatalk HD
    KTTB likes this.
    07-13-2013 08:36 AM
  1. audio jack problem
    By sol garcia in forum T-Mobile HTC One
    Last Post: 07-19-2013, 11:18 AM
  2. Google Nexus 4 volume help
    By Murali Krishna Gummadi in forum Google Nexus 4
    Last Post: 07-16-2013, 04:02 AM
  3. HELP. S4 shuts down randomly :|
    By Ashfid Islam in forum Samsung Galaxy S4
    Last Post: 07-13-2013, 02:26 AM
  4. Motorola Backflip Mb300 hanging logo need to help
    By vnmaxstructure in forum Motorola Backflip
    Last Post: 07-13-2013, 12:17 AM
