1. dodong27's Avatar
    Hey guys,
    I left my Note 2 inside my car during a hot weather for a couple of hours, and when I took it out of the car, my Note 2 started acting up and finally died. I charged it as soon as I got home but it wouldn't charge. The next day I tried to charge it again and it would hold charge and started to work fine while the charger is plugged in my Note 2. Though once I unplug the charger, my Note 2 dies! My Note 2 only works when it is plugged to the charger...
    Can someone help me???
    Thanks in advance!
    09-24-2015 03:39 PM
  2. SpookDroid's Avatar
    Have you tried replacing the battery? that's the first thing I'd test out. If with another battery the same behavior continues, then there might be something wrong with the power circuit inside the phone connecting the battery to the rest of the phone (in which case you'd need to take it in for repairs).
    tube517 likes this.
    09-24-2015 03:43 PM
  3. dodong27's Avatar
    No I haven't replaced the battery yet. I don't know anyone who has Note 2 where I can swap the battery to check if it is the battery that's acting up.
    Wanted to see if anybody had this problem before?
    09-24-2015 03:50 PM
  4. tube517's Avatar
    I use several batteries for my note 2. How old is the battery? Was it the original that came with the phone?
    11-05-2015 07:02 AM
  5. rhaneyjr's Avatar
    Ebay is your friend
    12-31-2015 05:50 PM
  1. Galaxy Mega Cannot Recieve Text Messages from iPhone
    Last Post: 09-24-2015, 06:47 PM
  2. Replies: 1
    Last Post: 09-24-2015, 06:45 PM
  3. How do I remove recorded downloads from my HTC One phone?
    Last Post: 09-24-2015, 06:35 PM
  4. Replies: 1
    Last Post: 09-24-2015, 06:29 PM
  5. Replies: 1
    Last Post: 09-24-2015, 02:54 PM
