1. DAS's Avatar
    I wanted to share with my fellow runners that if you are looking for a running solution to enable you to carry the Note on your run, I found that the Incipio Featherlite Case works really well, since it's so thin and adds no bulk, you don't have to remove it for it to fit into the armband.
    Below are links to the actual case & armband I use.
    http://www.amazon.com/Incipio-Samsun...cUvbUpU1745836
    http://www.amazon.com/BW-Neoprene-Ex...cUvbUpU1745836
    04-28-2012 09:47 AM
  2. Nimocone's Avatar
    I was waiting for a review on that armband and have had it sitting on my "wish list" on Amazon. How's it holding up so far and does the key pocket work?
    05-03-2012 09:29 PM
  3. DAS's Avatar
    The armband works so so. The good is that it does what it says, and allows you to carry the Note during a workout.
    The bad part is that it's really not made, despite what the description says, for the At&t version of the Note.
    The company modified mine to allow the headphone Jack to line up, but it's still a little difficult to press the on/off and volume buttons through the armband.
    I like it only because it does allow me to carry the Note, but its fit is really tailored for the international version.
    05-03-2012 10:32 PM
  4. Nimocone's Avatar
    Hmmm, now I'm not sure about it. I'm wondering if they would do another mod if I got one or if it's not worth the hassle. I'll assume you had to send it back.
    05-08-2012 08:21 PM
  5. DAS's Avatar
    They let me keep it and refunded the cost.
    It works, but it's not the best solution.
    Nimocone likes this.
    05-08-2012 08:48 PM
  6. Doyer's Avatar
    I found this arkon armband for the note that works pretty good, even has a cutout for the headphone jack:
    Arkon Smartphone Workout Armband for Galaxy Note & Phones Up to 5.3"
    08-27-2012 03:45 PM
  7. btswein's Avatar
    I've been looking for a solution to my generic Wal-Mart armband but never actually looked. This reminded me haha, cool.
    Thanks!
    Sent from my Galaxy Note.
    08-27-2012 05:01 PM
