1. crsezzell's Avatar
    My galaxy note phone says n red in top left "Factory mode". Underneath that is product name, custom binary mode:no, and current binary: samsung official. Also there is a large green android man in the middle of screen and under him is "Downloading.....Do not turn off target!"
    I have been having issues with it not charging lately, too. The phone will not come on. I have tried to restore (holding volume dwn, power and home), iv taken the battery in and out. I have not had the sim and sd cards in it since it has been messing up ...x1 week. A weird thing happened a few minutes ago....instead of using the standard charger, I set it on the dock; the phone cut on as it use to (normally), it showed my home screen..with all icons and the way I customized it....it stayed on for about 15 minutes, then went to this screen with the big green android man. Please HELP!!! Thanks to all of you who have knowledge in how to help me get it working properly again. Oh, and the warranty ran out last week :-/
    Sent from my GT-P5113 using AC Forums mobile app
    10-28-2013 07:24 PM
  2. Paul627g's Avatar
    Hello,
    The Downloading screen as you described is used in conjunction with a program called " Odin " to flash the device with different firmware. Its used to root the device or flash it back to factory stock.
    You mentioned the SIM card not being in it. Is it possible you have a corrupt SIM or its not seated properly?
    10-30-2013 09:23 AM
  1. Galaxy S3 auto-restart problem
    By zvika gl in forum Samsung Galaxy SIII I9300
    Last Post: 01-16-2016, 10:24 PM
  2. Samsung Galxay Note 10.1 (2014) How to activate handwriting to text in S note
    By wmg390 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-27-2014, 07:44 AM
  3. Note 3 with Google Services
    By duoFurious in forum Samsung Galaxy Note 3
    Last Post: 11-07-2013, 08:06 AM
  4. Samsung Galaxy S4 - 4.3 UI Changes?
    By AlphaVictor87 in forum Samsung Galaxy S4
    Last Post: 10-31-2013, 09:47 PM
  5. Sprint Galaxy S3 - Is there a master list of safe apps to delete?
    By Drummerboy1975 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-30-2013, 10:06 PM
