1. millerwa76's Avatar
    Mine is less than 3 months old and I'm lucky to get 4 hours of use out of it.....and that's just with low power sucking apps like internet, facebook, email, etc. Never mind if I try watching youtube videos or netflix.
    I called AT&T and they had me do a factory reset. This seemed to solve the problem for about 2 days. I guess my next step is to call Samsung and have them send me a replacement, but what a huge pita that's going to be. Just wondering if anyone else had the same problem.
    09-06-2014 10:33 AM
  2. B. Diddy's Avatar
    Review this guide and see if the tips help: http://forums.androidcentral.com/amb...ving-tips.html
    Also, do the following:
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    09-06-2014 12:51 PM
  1. Samsung s4 battery draining a little fast for me
    By Sammy Diab in forum Samsung Galaxy S4
    Last Post: 09-11-2014, 01:15 AM
  2. LG G2 Android OS battery Drain
    By James Skinner in forum LG G2
    Last Post: 09-07-2014, 11:30 AM
  3. Battery drain from Bluetooth?
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 09-06-2014, 04:50 PM
  4. Battery...
    By YahyaRivero in forum Samsung Galaxy Note 4
    Last Post: 09-06-2014, 11:03 AM
  5. Replies: 2
    Last Post: 09-06-2014, 07:30 AM
