1. gerelee54's Avatar
    anyone else think the volume of the ringers and notifications too low? i read the phone scoop review and he said they are very loud ... mine aren't loud at all, in fact they are pretty quiet
    10-03-2011 06:16 PM
  2. SteveISU's Avatar
    If you have them set all the way up and you still feel they are soft, go to an Audiologist and get checked out.
    10-03-2011 06:41 PM
  3. miller7796's Avatar
    I have mine set to the halfway point and still think they are loud.
    10-03-2011 08:01 PM
  4. ofcjscott's Avatar
    Yup, you either got earwax buildup or too much hair in them ears if you think the ringers are too low. Mines r way loud.
    Sent from my Toshiba Thrive w/Google using Tapatalk
    10-03-2011 08:13 PM
  5. gerelee54's Avatar
    thank you ... maybe there is a problem with mine .. i'll ignore the other posts
    10-03-2011 09:48 PM
