1. riekls's Avatar
    So I like power save as it squeezes more time out of the battery. But when I charge the phone back up, all of the power save settings are still on, super annoying to have my phone turning off after 5 seconds when its fully charged Why does this happen? Anyone have a fix for it?
    10-05-2011 09:20 AM
  2. riekls's Avatar
    no one else has this problem ?
    10-05-2011 12:49 PM
  3. dewhite04's Avatar
    I noticed the same thing, and had the same disappointment. Hopefully something that gets updated as we go along, but not something I'm going to hold my breath for...
    10-05-2011 12:57 PM
  4. runtohell121's Avatar
    Same problem here.. :/
    10-05-2011 02:08 PM
  5. timberga's Avatar
    Weird, I believe the galaxy tab 10.1 has this feature....don't quote me on it tho.
    10-05-2011 02:23 PM
  6. lilo777's Avatar
    As I understand, when power save mode is enabled (by user) the phone displays the icon in the status (notification) bar and a message in the notification list. It does not mean that the mode is actually activated. I believe when the battery charge drops below the threshold level, the phone activates the mode and changes the icon color. I believe I saw this behavior bu i did not try to double check it.
    10-05-2011 05:33 PM
  7. Strawdawg's Avatar
    X2, mine appears to work that way
    10-05-2011 05:35 PM
  8. runtohell121's Avatar
    The notification message says "Power saving mode enabled" when my battery is at 100% or even at 76%.. I set it to enable power saving mode at 50%..
    10-05-2011 05:50 PM
  9. shansmi's Avatar
    that just means it is watching, not taking action. Set you phone to vibrate on all actions and you'll get the vibrate icon in the banner as well.
    10-05-2011 06:12 PM
  10. boscosblues's Avatar
    My 10.1 does the same thing... Fully charged set for 10% and 30 min. It times out after about 5 min. Tops... Very frustrating... I have the US Cellular model and am about to give it back to them... There is no way I have found to turn off power saver mode
    06-18-2012 02:12 AM
  11. psufan32's Avatar
    The icon simply means that you have selected to have PSM turn on when your phone hits X% of battery power left. The icon is always showing, that's just how it is.
    One annoying thing that I've noticed is that I typically set my screen brightness to Auto, however, on days when I drop below 30% power and PSM enables, it turns brightness down, turning off Auto brightness (which I've set PSM to do), but when I charge my phone back up, I have to manually enable Auto brightness again.
    06-21-2012 08:23 AM
  12. Tom Young2's Avatar
    Mine did this, and I had to manually go into the display settings and set them back. I don't know why it doesn't automatically go back to standard settings when recharged, but it worked to do it manually!
    12-25-2014 04:58 PM
