1. CardboardDreams1984's Avatar
    I can't get my GS2 to recognize my 16GB MicroSD (HC) card. I've tried a smaller 4 GB with no luck either. In the Storage menu it says the space is unavailable (even with no card), and the mount SD card and Format SD card options are also greyed out (again even with no card). Windows only recognizes the internal 11.3 GB of storage, too. What do I need to do to get SD card storage?
    10-05-2011 06:37 PM
  2. brendonlee's Avatar
    Try putting the card into a card reader on a PC and format FAT or FAT32
    Sent from my SAMSUNG-SGH-I777 using Tapatalk
    10-05-2011 06:47 PM
