1. aBrant5's Avatar
    I have another question.. this morning, I tried to turn my mobile data on. And it didn't come on.. and I haven't been able to get it to work for the rest of the day. I'm really not sure what is wrong.
    12-08-2011 03:32 PM
  2. aBrant5's Avatar
    12-10-2011 02:36 PM
  3. brendonlee's Avatar
    Reboot? Otherwise you gotta give more information than "it wont turn on"...is there an error? How are you trying to turn it on? Can you provide a screen capture of what you're seeing?
    Sent from my SGH-I777 using Tapatalk
    12-10-2011 07:11 PM
  4. aBrant5's Avatar
    I've rebooted many times. I go to settings, then wireless and networks, then mobile date, then then on "use packett data." I used to do this all the time, I would only turn it on when I needed it, but now it won't even turn on.
    12-14-2011 08:43 PM
  5. tunie's Avatar
    When you say it won't turn on, do you mean you can select the "Use Packet Data" with a check mark, but the data doesn't come on? Can you connect to wi-fi? Have you flashed any ROM's?
    This may be an obvious one but, in settings under Wireless and Network, is Flight Mode checked?
    12-14-2011 09:39 PM
  6. aBrant5's Avatar
    No, flight mode isn't checked. Lol. And yes, I check use packet date, and the data doesn't turn on. And yes I can get on wifi.
    12-14-2011 09:44 PM
  7. tunie's Avatar
    I know...:-), but I had to ask about Flight mode lol If you can get on w-fi, then it's probably a carrier issue. They're upgrading their network and I know of others who have experienced data issues because of it, or it might be an outage. I'd call AT&T and let them know you're having data issues. <edit> If it is them, can you let us know?
    12-14-2011 10:05 PM
  8. aBrant5's Avatar
    I will do that! I wasn't sure if maybe it was something I downloaded that shut it off, but I doubt it. I'll go to the at&t store and ask them about it.
    12-14-2011 10:18 PM
  9. tunie's Avatar
    You can also call AT&T CS. They seem to be very willing to help. I even think it might be better if you call because sometimes the sales people in the stores aren't all that knowledgeable. Well, the store here isn't that great, anyway. Yeah, if you couldn't get onto wi-fi, then it would most likely be your phone. Hope they can help:-)
    12-14-2011 10:30 PM
  10. aBrant5's Avatar
    I did an online customer service chat, and they basically had me do everything that I had already tried, and then told me to do a factory reset. I didn't want to do that, but it seemed like I had to. I reset it, and now everything is fine. Thanks for all the help!
    12-21-2011 08:54 PM
  11. tunie's Avatar
    Awesome! I'm surprised that only your wifi was effected. That's how much I know! Thanks for letting us know. I sure learned something here. Glad it's working for you! :-) I hate factory resets too, but I guess it's the only way sometimes.
    12-22-2011 12:31 AM
  12. Ardit Qeriqi's Avatar
    Hi i got that problem too. And i solvve that by pressing the number of megabyte servis for ex *888*1# tell me how megabyte i have and than my mobile data enabled
    P.s sorry for my engllish
    06-21-2015 04:22 AM
