1. Kranica's Avatar
    Hey guys, so yea, over the att network, these are the numbers I'm getting using speedtest. Anyone experiencing the same problem or have any suggestions?
    01-19-2012 09:16 PM
  2. runtohell121's Avatar
    how much data have you consumed? are you on unlimited data plan? have you used over 2gb? if so, you might be throttled.
    01-20-2012 12:46 AM
  3. Kranica's Avatar
    Yes I am on the unlimited data plan. I thought about that, but wouldn't it also affect the upload speed? Is there a way to verify if my network speed is being throttled or not?
    01-20-2012 03:06 AM
  4. runtohell121's Avatar
    Upload speed don't really get throttled. Only download speed does. I'm assuming you used more than 2gb already on AT&T "unlimited" data plan. If so, most likely your speed been throttled. Throttled speed is usually around 0.20 mbp/s or so when running speedtest app.
    01-20-2012 12:58 PM
  5. Kranica's Avatar
    ok, sounds about right. Thanks
    01-20-2012 04:26 PM
  6. NEDNERBISH's Avatar
    You know what's weird? At our at&t store their wiring isn't configured correctly. Every time I go there my internet is awful.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk
    03-15-2012 09:09 AM
  7. NEDNERBISH's Avatar
    Wifi, not wiring
    03-15-2012 09:09 AM
  8. dingbat005's Avatar
    the wifi in the stores is so bad because they have every phone in the store running on it
    03-20-2012 11:19 AM
  9. NEDNERBISH's Avatar
    Ahhhhh haa! That makes sense
    03-21-2012 09:10 AM
