1. robcassman's Avatar
    I've always had terrible battery life but in the past week I only get it about 8-9 hours out of it (pretty light use.) My screen shot is after being unplugged for only one hour (though it reads "5 seconds) and it has dropped 14%.
    Now my phone's battery icon flashes, almost continuously. Sometimes, while not plugged in it will have the "charging" battery icon showing and will make the sound as if I am plugging it in, then unplugging continuously.
    04-10-2013 09:08 AM
  2. TxAndroidGuy's Avatar
    Have you tried restarting your phone? It's odd that screen would show 50% usage with light use. Do you have any new app installs recently that may be keeping the screen on? You may want to try installing Wakelock detector from the Play store and letting it run to see if there are any apps running in the background. I hope that helps!
    04-10-2013 01:11 PM
  1. Battery Problem?
    By jdivers03 in forum Motorola Droid X
    Last Post: 07-22-2010, 09:36 AM
  2. droid incredible battery problems
    By Droid User11 in forum Verizon Droid Incredible
    Last Post: 07-16-2010, 10:51 AM
  3. Possible Cause for battery problems, 3G
    By Ace41690 in forum HTC EVO 4G
    Last Post: 06-12-2010, 11:31 AM
  4. Having a battery problem with Droid
    By StingrayJG in forum Motorola Droid
    Last Post: 06-08-2010, 08:54 AM
  5. HTC Hero (Seious battery problems)
    By tomwazza in forum HTC Hero
    Last Post: 12-19-2009, 08:29 AM
