1. rgamr's Avatar
    So I got a zerolemom extended battery a couple of days ago and was super busy excited because the battery would make my phone last so long, however that is not the case. After charging the phone for 10 hours or so I then proceeded to use it and the battery drained in 6 hours (my 4200 hyperion battery last almost triple that) and so I thought if I charged it then it would be fine. Not the case because I did and the battery drained again all the way to 3 percent in roughly the same time, however what was different was that the 3 percent last for 2 hours on somewhat intense gaming. So my question was is the battery faulty or is the phone reading the battery wrong.
    03-25-2013 09:02 AM
  2. meyerweb#CB's Avatar
    You didn't say whether, after the 10 hour charge it was 100% charged or not.
    The generally accepted method to "calibrate" a new battery is to charge it to 100%, then let it drain until the phone shuts off by itself from lack of power, then do it all again. Try that and see what happens.
    03-26-2013 02:02 PM
  3. Joseph Will's Avatar
    having the same issue NOW although Ive had the zero lemon for abbout a month. It SAYS its 100% charged in the morning when I wake up but drops to 50% within an hour and then to about 20 % after a day and a half not charging.
    want to know if the other posters advice WORKED for you...to let it drain until the phone kills the battery to "calibrate" it??
    thanx anybody who has this answer.
    09-02-2013 01:27 PM
  1. Samsung Droid Charge is not reading my SIM card!?
    By AnjanVS94 in forum Verizon Droid Charge
    Last Post: 04-09-2012, 07:42 PM
  2. My Blackberry is not working!
    By ChrisGonzales90 in forum Legacy Android & Other OS's
    Last Post: 01-05-2011, 12:13 AM
  3. My Market is not downloading
    By myersjesse in forum Motorola Droid X
    Last Post: 10-31-2010, 09:21 PM
  4. The official my battery is dead for the first time.
    By OrderedtheEvo in forum HTC EVO 4G
    Last Post: 06-04-2010, 10:44 AM
  5. my phone is not rooted, can I flash Damages 2.0.6 to my sd card
    By laraiza in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 04-12-2010, 12:41 AM
