1. bowles1231's Avatar
    Randomly, the mic stopped working on my galaxy s3. I switched to speakerphone (to use other mic), nothing. Headphone mic not working either. This tells me that its a software issue, but after flashing a recovery (completely different rom, and stable) I'm still having the same issue. Where do I go from here?
    07-15-2013 11:22 AM
  2. Golfdriver97's Avatar
    I would suggest to wipe cache on recovery. In case you don't know how go here: http://forums.androidcentral.com/sam...2-s3-tab2.html
    07-15-2013 11:36 AM
  3. bowles1231's Avatar
    Thanks. I've done so, wiped data/factory, installed new roms.. nothing
    07-15-2013 12:13 PM
  4. Golfdriver97's Avatar
    As of this point, I don't know what else to suggest. Sorry.
    Sent from a SlimROM S3.
    07-15-2013 05:55 PM
  5. bowles1231's Avatar
    Any other ideas?
    07-15-2013 07:27 PM
  6. Golfdriver97's Avatar
    Any other ideas?
    So, you are on a different ROM? If so, I would flash a stock back on. If this fixes it, then it is software. If not, it is hardware.
    07-15-2013 11:13 PM
  7. bowles1231's Avatar
    I've just gone back to stock, still nothing. I'm just confused as to where the hardware issue lies. I'm confident enough to replace most of the inner components, just not sure where to start. Any suggestions? Thanks for your time by the way.
    07-16-2013 03:22 PM
  1. help with ipp podcast player locating songs.
    By m444nsn in forum General Help and How To
    Last Post: 09-06-2013, 01:13 AM
  2. Help with Airplane Mode
    By jerryferreira in forum General Help and How To
    Last Post: 07-30-2013, 01:31 PM
  3. Text messaging help please!
    By Jenny Coats in forum Samsung Galaxy S4
    Last Post: 07-16-2013, 12:20 PM
  4. Antutu Crash problem??
    By Medicine_Man_420 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-15-2013, 06:43 PM
  5. Google All Access Radio Is Bad - Is it Just Me?
    By David Kilmnick in forum General News & Discussion
    Last Post: 07-15-2013, 10:18 AM
