1. HiIslands's Avatar
    How do I change the default Android Image that appears for incoming calls?
    04-18-2011 10:58 AM
  2. KCMike's Avatar
    That's a good question. I wouldn't mind seeing if this was possible as well.
    04-18-2011 11:18 AM
  3. Patg88's Avatar
    Open contact > pick one you want to change > menu> edit > left of the name you will see a profile picture click on that and you will get a drop down menu gallery, camera etc. Pick what you want to show up when that person calls you. That's it.
    04-18-2011 03:39 PM
  4. KCMike's Avatar
    I've done that before.
    I was actually hoping for a way to do a batch change for all users at once.
    04-18-2011 04:16 PM
  5. ednygma's Avatar
    If you sync your contacts with Facebook it will grab their profile pic and display that when they call.
    04-19-2011 09:53 AM
  6. dcdenonda's Avatar
    what you guys are explaining is how to set picture caller ID, I think he wants to know if you can change the default android guy picture for all incoming calls.
    which to my knowledge...it cant be done
    04-19-2011 06:07 PM
  7. bossawesome's Avatar
    I know exactly what you want and there's only way I know of to do it...grab RocketDial off the market. It has a dialer, a contact manager and overrides the caller ID once you adjust the settings. It also asks what you would like your default picture to be and uses HD pictures. I have used it for my last 3 phones.
    01-17-2015 11:14 AM
