So I received a message that my update was available this morning. I tapped on the update now box and was connected to my wifi at home. The phone shut down and proceeded to reboot, however now it goes to a screen with the android icon and an exclamation point in a triangle. When I go into clockwork recovery to try and install the update manually, it comes up that the signature check fails. I tried disabling the signature check and the update tries to install then aborts (status 7). Has anyone else run into this problem? How do I get this to work without having to completely wipe my phone data? If that's the rout I have to go I will, just don't want to lose everything again.
My phone is rooted also.
Thanks!
Thanks!
