1. Hermdroid's Avatar
    Ok long story short I erased all my contacts on gmail.com. They're still on my phone and when I tried to sync to gmail again from my phone only 13 contacts showed up! Is it something I'm doing wrong? I would like to get ALL my contacts from my phone back to gmail in case something happens!
    05-09-2011 11:55 AM
  2. ddot196's Avatar
    I did it thus way to get my contracts on to gmail as I was having problems. Save all your contacts as a file using your app. I use go contacts and there is an option to save my contacts as a file on the phone. Once that was done I connected my phone to the computer and went to gmail on my computer. I then selected upload contacts and chose the file on my phone and they all loaded up into gmail. Now I presume if I ever lose them I'll be able to go too gmail and just import them to my phone.
    Sent from my HTC Inspire 4G
    05-09-2011 01:27 PM
  3. Hermdroid's Avatar
    Took me a minute but my problem is fixed thanks to your method. Thanks!!!
    05-09-2011 07:08 PM
  4. raver_returns's Avatar
    I'm just curious. Does this method still provide an accurate two way sync as I add or change contacts from both the phone or the gmail account?
    05-09-2011 07:23 PM
  5. Hermdroid's Avatar
    Well when I did it this way.I made sure all my contacts synced to Google. After that I deleted all the contacts on my phone. Then on Google made a export file and copied it to the SD card. Then imported that data to my phone so my phone is now saying all contacts are synced to Google.
    05-09-2011 08:22 PM
