Save big + get 3 months free! Sign up for ExpressVPN today
Sideloading woes. Found fix, breaks mms.
- True...I might do this...I have the option to take the phone to get a new one but I am going to have everything wiped out and everything...settings etc...and that is why I dont do a factory reset cause if ima lose everything I might as well get a new phone haha06-08-2011 08:17 PMLike 0
Sent from my Desire HD using Tapatalk06-08-2011 08:50 PMLike 0 - Right, getting a new phone and doing a hard reset isn't going to be much difference setting it up again, but you might consider the chance you might get a bad one when you already know you have a good one. I had to return my first Inspire because the screen went out. Was I glad that happened. The first one had a faulty gps that I wasn't fully aware of until I saw how much better my current one works. The opposite could happen. Just something to consider.
Sent from my Desire HD using Tapatalk06-09-2011 01:34 AMLike 0 -
You can use GO MMS which will upload it to them and send the other person a link to it though. Not the same.
GO SMS is worth the download though. So much better than the stock messaging app.06-09-2011 08:02 PMLike 0
- Forum
- More Android Goodness
- The Archives
- Android Central Archives
- HTC
- AT&T Inspire 4G
