homescrub
Hard reset was a colossal pain in the ass. Took 30 min just to reload all my apps and widgets. This solution is terrible.
It really does suck.
Ouch. My mms didn't have a prob. someof u might hafta have a device support store look at it :/
Same happened to me was on phone for 2 hours with att they couldn't figure t out so I had to reset my phone and now it works perfect took me over an hour together it back the way it was PITA
Hard reset the phone. MMS back up and running baby!!!
Just use Go SMS Pro and MMS works fine
there is no reason why i should have to incorporate a 3rd party messaging system when i want my original messaging services of which I am paying $30 for.
True...I might do this...I have the option to take the phone to get a new one but I am going to have everything wiped out and everything...settings etc...and that is why I dont do a factory reset cause if ima lose everything I might as well get a new phone haha
Right, getting a new phone and doing a hard reset isn't going to be much difference setting it up again, but you might consider the chance you might get a bad one when you already know you have a good one. I had to return my first Inspire because the screen went out. Was I glad that happened. The first one had a faulty gps that I wasn't fully aware of until I saw how much better my current one works. The opposite could happen. Just something to consider.
Sent from my Desire HD using Tapatalk
people, if I want orange soda, why are you trying to give me orange juice.
