I got them from the android dev website I downloaded the existing ide sdk file, and followed instructions on xda
nope it's been three days and nothings working(-_-) I'm having the exact same problem with sprint..... did you make any progress with fixing your phone?
Where did you get the files to use ADB ? I tried googling but not sure which is genuine.
Sent from my iPhone using Tapatalk
My phone automatically updated an ota update and now it only boots to Clockworkmod recovery v6.0.4.4. I've tried restroing from backup, wiping my dalvik cache and cache, then factory resetting but nothings working. Please help me
In XDA is the solution (the thread is for TWRP but works in CWM as well, I did it)
[FIX] Installed TWRP and now you're stuck after OTA? - xda-developers
