This is what is in the log files i got when trying to unbrick
[16:33:09:420] : =============================================
[16:33:09:420] : Log is started on 24.01.2012, at 16:33:09:420,
executable: C:\Users\Sexy Babe\Downloads\KDZ_FW_UPD_EN\KDZ_FW_UPD.exe (ProcID: 0x00000f5c),
compile time : Dec 3 2010 21:03:18
[16:33:09:420] : Version :
[16:33:09:422] : Get Usb Port
[16:33:09:426] : rsi.strFriendlyName=LGE Android Platform USB Serial Port (COM7)
[16:33:09:426] : FriendlyNameList[iii].szFriendlyName=LGE Android Platform USB Serial Port
[16:33:09:426] : WM_COPYDATA ???? ???? 1 - COM7
[16:33:09:426] : Port = COM7
[16:33:09:429] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:430] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:431] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:431] : >> DIAG_STATUS_F FAILED
[16:33:09:436] : >>Get Model Name [DIAG_VERNO_F]
[16:33:09:437] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:438] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:439] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:440] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:441] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:442] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:442] : FAIL (No Phone)
[16:33:09:442] : GetModelName() Operation Failed Check Diag CMD
[16:33:09:442] : EMERGENCY Booting Mode
[16:33:09:442] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F]
[16:33:09:443] : BS/P506/7DEXYBA~1\AppData\Local\Temp\DZ
[16:33:09:443] : WM_COPYDATA ???? ???? 0 - P506
[16:33:09:454] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:454] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:455] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:455] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:456] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:456] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:456] : NV Write Fail : NV ITEM 9028(9028)
[16:33:09:556] : >> GET DLOAD COMM MODE
[16:33:09:557] : [GetCommMode] Communication mode : 2
[16:33:09:557] : Pre Nand Download
[16:33:09:557] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted)
[16:33:09:557] : WM_COPYDATA ???? ???? 3 - TRUSTED MODE
[16:33:09:568] : [COM7] >>NandFlashInitWithFile(PARTITION TBL)
[16:33:09:568] : WM_COPYDATA ???? ???? 3 - INIT PARTITION TBL
[16:33:09:660] : ???? ???? TYPE_WPARAM_WRITE_TO_SDRAM 3
[16:33:09:660] : [COM14] ???? ???? TYPE_WPARAM_WRITE_AMSS 15
[16:33:09:660] : [COM7] >>NandFlashInitWithFile(AMSS MODEM HEADER)
[16:33:09:664] : WM_COPYDATA ???? ???? 3 - INIT AMSS MODEM HEADER
[16:33:09:675] : [COM14] >>Dl_AsyncWrite()
[16:33:09:675] : >> AMSS FLASHING ...
[16:33:09:679] : ???? ???? ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0
[16:33:09:679] : Sending Pkt Seq : 0
[16:33:09:680] : Sending Pkt Seq : 1
[16:33:09:680] : Sending Pkt Seq : 2
[16:33:09:680] : Sending Pkt Seq : 3
[16:33:09:680] : Sending Pkt Seq : 4
[16:33:09:680] : Sending Pkt Seq : 5
[16:33:09:680] : Sending Pkt Seq : 6
[16:33:09:680] : Sending Pkt Seq : 7
[16:33:09:681] : Sending Pkt Seq : 8
[16:33:09:681] : Sending Pkt Seq : 9
[16:33:09:692] : Dl_AsyncWrite - ErrNo(45), Addr(0x00004800), NandErrNo(0x04)
[16:33:09:692] : [COM14] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH
[16:33:09:692] : WM_COPYDATA ???? ???? 3 - Close Port
[16:33:09:692] : Close Port<<
[16:33:09:692] : TYPE_WPARAM_UPGRADE_ERROR
[16:33:09:692] : ???? ???? - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008
[16:33:09:749] : Log finished
