There is an issue with Joban's How-To. Sometimes the drivers don't install from the phone like they are supposed to (often times). If you use the programs/files that Joban has listed on the first page it will get you really close but wont get you all the way. It will never install the proper USB drivers. So you will need to download the program I have attached (its from LG no worries). Once you get it all unzipped and ready to go you need to lie. At this point you need to convince the program you speak English and you live in Singapore [yes I know just do it]. Click on Options & Help>Country &Language, then select accordingly. Then you will need to click on "Install Driver" At this point it will ask you to select a carrier, select "Quality One" then click LGP509. This is another clone of the Optimus One and the drivers are the same. If all goes well it should install 3-4 files (I can't remember off hand I'm doing this from memory). After you have the drivers installed its just a matter of following the rest of Joban's writeup. If this doesn't work let me know and I will try to recreate the files and just upload the drivers directly.
