07-22-2014 12:53 AM
469 1234 ...
tools
  1. d10nt3's Avatar
    Camera, Google Now, Voice search, screen on/off animation
    Sadly google now isn't working yet /: I was looking forward to that. I can't get anything to work however.
    07-20-2012 05:07 PM
  2. Oathkeeper1212's Avatar
    Looking into it now.
    Sent from my LG-P505 using Tapatalk 2
    07-20-2012 05:13 PM
  3. Rashed1997's Avatar
    OK I'll upload my working P505 Wifi build
    Told you you should have synced Oathkeeper :P
    Fixed P505 Wifi: http://dl.dropbox.com/u/56064156/CM1...ICIAL-p505.zip
    07-20-2012 05:24 PM
  4. Oathkeeper1212's Avatar
    Guys use apex launcher or nova launcher as a replacement while we figure out how to fix the stock launcher.
    07-20-2012 05:26 PM
  5. Oathkeeper1212's Avatar
    Updated link with WORKING WIFI :P
    07-20-2012 05:30 PM
  6. Rashed1997's Avatar
    Not working:
    All video playback: Qualcom removed all video support for ARMv6 devices in JB
    The next releases will contain a fix to this
    ADB over network: Next release will contain a fix
    Radio: I have no idea when we can fix
    More as it comes
    07-20-2012 05:34 PM
  7. Rashed1997's Avatar
    Can you explain a bit more?
    I'm working on a GNow fix ATM
    Oathkeeper1212 likes this.
    07-20-2012 05:35 PM
  8. d10nt3's Avatar
    Well, when I flashed it, I booted up and when I got to the standard new phone welcome screen, I got a whole bunch of errors saying different apps crashed such as phone.android and a few others. And yes, I wiped everything before I flashed it.
    07-20-2012 05:57 PM
  9. Rashed1997's Avatar
    Hm weird..
    I got that phone one but the phone works fine...
    Can you get a list of all of them?
    07-20-2012 05:59 PM
  10. bill.weckel's Avatar
    First of all, HELL YEAH!!! Thanks devs.
    WiFi works for me. In fact I'm using it now. A few things...
    1) got com.android.phone fc on first boot
    2) Date is correct, time is not. My timezone is GMT-4 and the reported time is 4 hrs later than the actual time. This is also with the setting to use network time enabled.
    3) Notification bar doesn't show widgets/toggles
    Nothing else at the moment. This ROM seems pretty quick. Haven't had a chance to do much else.
    Sent from my LG-P506 using Android Central Forums
    07-20-2012 06:34 PM
  11. Oathkeeper1212's Avatar
    1) That fc hasn't been fixed,it's normal. it's the same for us and P500 users.
    2) You will have to manually adjust, another bug :/
    3) Jelly bean doesn't have toggles in it.
    By the way, I've began building again, a few changes have been added to the lgics githug, and Cyanogenmod has added ALOT of changes Will let you know how it goes.
    07-20-2012 06:58 PM
  12. PoisonedPanther's Avatar
    I installed this rom and every second it popped up that com.android.phone closed. I am on rogers and am in a non service area if that helps.
    07-20-2012 07:06 PM
  13. Oathkeeper1212's Avatar
    When you connect to a service provider it will stop.
    PoisonedPanther likes this.
    07-20-2012 07:08 PM
  14. PoisonedPanther's Avatar
    Ok thanks. Too bad I can't connect where I am. Will it stop if i turn on airplane mode?
    07-20-2012 07:11 PM
  15. PoisonedPanther's Avatar
    I just tried downloading and it gave me a 404. Just so you know Oathkeeper. Downloading from Rashed's link.
    07-20-2012 07:17 PM
  16. failed1234's Avatar
    Err... Dropbox link seems chopped off. I get a 404 error whenever I click it.
    Edit: Woops, comment above me has that covered.
    07-20-2012 07:20 PM
  17. bill.weckel's Avatar
    @ 3) . Then why are there options for them in Settings->System->Notifications ? Confusing...
    One more thing. My ext partition isn't getting mounted. I'm unable to use Link2SD.
    07-20-2012 07:27 PM
  18. PoisonedPanther's Avatar
    I just tipped the post as newsworthy and that it should go on the blog.
    07-20-2012 07:31 PM
  19. Oathkeeper1212's Avatar
    Ok, i will reupload the working wifi version. Sorry about that.
    07-20-2012 07:45 PM
  20. Oathkeeper1212's Avatar
    Thanks man!
    07-20-2012 07:46 PM
  21. Oathkeeper1212's Avatar
    Remember what i said in the first post, alot of things will not be implemented yet, they will come in future updates from the Cyanogenmod team.
    07-20-2012 07:47 PM
  22. PoisonedPanther's Avatar
    Thanks man!
    You're welcome!
    Now that i reinstalled working wifi version it also says Email stopped. Going back to ICS until I get to a service area.
    07-20-2012 07:48 PM
  23. bill.weckel's Avatar
    :o
    07-20-2012 08:00 PM
  24. Oathkeeper1212's Avatar
    You're welcome!
    Lol, alright, i'm reuploading rashed's working wifi version.
    07-20-2012 08:02 PM
  25. d10nt3's Avatar
    Hm weird..
    Sorry for the late reply, I was hanging out with some friends. But I'll give you a full list when I get back on the rom. I went back to ics for the time being.
    07-20-2012 08:12 PM
469 1234 ...
Tags for this Thread
