1. trinhtran's Avatar
    I'm thinking this is the microSD card's problem. For the last month, my Polaroid 32 GB CL10 micro SDHC Flash Memory Card worked fine. These few weeks, I notice some weird change in the memory itself. Some of my pictures became weird colored and some have half grey and half my picture. When I take it out to look and put it back, the phone could not read it anymore. It said no memory card is inserted. How can I revive this?
    05-12-2013 07:57 PM
  2. GMJeff's Avatar
    Try to see if you can get it to read on a computer, or a different device.
    There have been a lot of people on the forums in the past six months or so complaining about corrupted sd cards, and you may have the same problem.
    Once the file allocation table of the card is corrupt, that usually means all data is lost. There are some specific software applications made for non destructive data recovery. I have used a few to do just this on hard drives that have failed.
    I am crossing my fingers for you that this is not the case and you can recover all of your data.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    05-12-2013 10:02 PM
  1. Dropped my Bolt. Now it won't read the SD card -__-
    By 808TBolt in forum Verizon HTC Thunderbolt
    Last Post: 03-25-2013, 03:34 PM
  2. How to remove and insert the microSD card
    By Phil Nickinson in forum AT&T Samsung Infuse
    Last Post: 06-20-2012, 02:15 PM
  3. Acer 200. How to access/open the MicroSD card slot?
    By sheishere6 in forum Acer Iconia A200
    Last Post: 02-02-2012, 08:40 PM
  4. My Amaze isn't recognizing the microsd card
    By sebastiau in forum T-Mobile HTC Amaze 4G
    Last Post: 10-13-2011, 10:15 AM
  5. Media Management & the MicroSD Card
    By baycruisers in forum ASUS EeePad Transformer
    Last Post: 07-23-2011, 04:43 PM
