1. davidrenjenkins's Avatar
    Hi, I bought a phone from an AT&T customer, and presently have an AT&T 4.1.2 build. (N7105 phone) But I am using it on TMobile. I want to update to 4.3. TMobile Samsung kies only tries to re-update to 4.1.2 and when I check for an OTA update (says through AT&T servers) it says there aren't any updates. It might be checking TMobile servers instead.
    I have been into a Best Buy and the Samsung Rep flashed it with his laptop and all it did was flash to 4.1.2 AGAIN. He said maybe check out a custom ROM. I want Photosphere and Galaxy Gear capability as well as SPen support, etc.
    Can I change to go through AT&T servers? (also the Samsung reps said AT&T was having problems with Gear support for Note 2) Any recommendations or thoughts on good custom ROMS?
    Thanks!
    David
    12-30-2013 01:33 PM
  1. Note 3 case questions
    By ShaggyKids in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-01-2014, 08:02 PM
  2. Note 3 lock screen notification issue
    By MissMystikle in forum Samsung Galaxy Note 3
    Last Post: 12-31-2013, 08:35 AM
  3. need help :/
    By samrakhan in forum General Help and How To
    Last Post: 12-30-2013, 09:13 PM
  4. WiFi on -lte turns of
    By sammy1412 in forum Droid RAZR MAXX
    Last Post: 12-30-2013, 02:29 PM
  5. No sim card after JB on Atrix HD
    By tangonet1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-30-2013, 12:47 PM
